X570 Chipsatztemperaturen
Autor Thema: X570 Chipsatztemperaturen  (Gelesen 4436 mal)
HTO
« am: 10. November 2020, 18:51:10 »
Liebes Forum,
ich benutze seit einiger Zeit einen Ryzen 3700X auf einem X570 Gaming Edge Wifi. Als Betriebssystem setze ich Manjaro mit einem 5.9er Kernel ein.
Wenn ich die Hardwaresensoren auslese, sind einige etwas komisch [1]. Unter anderem die PCH-Temperaturen werden alle mit 0.0 beziffert.
Gibt es da einen Trick oder wird der Nuvoton-Chip einfach nicht richtig unterstützt?
HTO
[1]
nct6797-isa-0a20
Adapter: ISA adapter
in0:                     1.09 V  (min =  +0.00 V, max =  +1.74 V)
in1:                     1.01 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in2:                     3.34 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in3:                     3.34 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in4:                     1.01 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in5:                   152.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in6:                   536.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in7:                     3.34 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in8:                     3.31 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in9:                     1.79 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in10:                    0.00 V  (min =  +0.00 V, max =  +0.00 V)
in11:                  488.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in12:                    1.13 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in13:                  712.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in14:                    1.53 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
fan1:                  2250 RPM  (min =    0 RPM)
fan2:                  1261 RPM  (min =    0 RPM)
fan3:                   631 RPM  (min =    0 RPM)
fan4:                  1785 RPM  (min =    0 RPM)
fan5:                  2051 RPM  (min =    0 RPM)
fan6:                   912 RPM  (min =    0 RPM)
fan7:                     0 RPM  (min =    0 RPM)
SYSTIN:                 +45.0°C  (high = +80.0°C, hyst = +75.0°C)  sensor = CPU diode
CPUTIN:                 +48.0°C  (high = +115.0°C, hyst = +90.0°C)  sensor = thermistor
AUXTIN0:                +55.0°C  (high = +115.0°C, hyst = +90.0°C)  sensor = thermistor
AUXTIN1:               -128.0°C    sensor = thermistor
AUXTIN2:                +59.0°C    sensor = thermistor
AUXTIN3:                 -2.0°C    sensor = thermistor
SMBUSMASTER 0:          +65.0°C
PCH_CHIP_CPU_MAX_TEMP:   +0.0°C
PCH_CHIP_TEMP:           +0.0°C
PCH_CPU_TEMP:            +0.0°C
intrusion0:            ALARM
intrusion1:            ALARM
beep_enable:           disabled
