neue MSI-Boards
Autor Thema: neue MSI-Boards  (Gelesen 6129 mal)
neue MSI-Boards
« am: 08. Oktober 2007, 23:25:01 »
Bei MSI kündigen sich ein paar neue Boards an.
MS-7359 - G33D3M Series
Processor
- Intel Core 2 Extreme, Core 2 Quad, Core 2 Duo, Pentium and Celeron in the LGA775 package
FSB
- 1333/ 1066/ 800 MHz
Chipset
- North Bridge: Intel G33 chipset
- South Bridge: Intel ICH9/ ICH9R chipset
Memory
- DDR3 1066/ 800 SDRAM (8GB Max)
- 4 DDR3 DIMM slots (240pin / 1.5V)
LAN
- Realtek RTL8111C Gigabit Ethernet controller
IEEE 1394 (Optional)
- Chip integrated by VIA VT6308P
- Transfer rate is up to 400Mbps
Audio
- Chip integrated by Realtek ALC888
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 spec.
- Meets Microsoft Vista Premium spec.
Floppy
- 1 floppy port
- Supports 1 FDD with 360KB, 720KB, 1.2MB, 1.44MB and 2.88MB
IDE
- 1 IDE port by Marvell 88SE6111
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
SATA
- 4 SATA II ports by ICH9 (2 eSATA for Windows Vista)
- 6 SATAII ports by ICH9R (2 eSATA for Windows Vista)
- 1 SATA II port by Marvell 88SE6111
- Supports storage and data transfers at up to 300MB/s
RAID
- SATA3~6 support RAID 0/ 1/ 0+1/ 5 or JBOD mode (for ICH9R only)
Connectors
Back Panel
- 1 PS/2 mouse port
- 1 PS/2 keyboard port
- 1 VGA port
- 2 eSATA ports (hot plug supported by ICH9R)
- 6 USB 2.0 Ports
- 1 LAN jack (10/100/1000)
- 6 flexible audio jacks
- 1 1394 port (Optional)
Onboard Connectors
- 1 front audio connector
- 2 front panel connectors
- 1 CD-In connector
- 3 USB 2.0 connectors
- 1 serial port connector
- 1 chassis intrusion switch connector
- 1 SPDIF-Out connector
- 1 1394 connector (Optional)
Slots
- 1 PCI Express x16 slot
- 2 PCI Express x1 slots
- 1 PCI slot (supports 3.3V/ 5V PCI bus interface)
Form Factor
- Micro-ATX (24.4cm X 24.4cm
MS-7395 - P35 Neo3 series
Processor Support
- Intel® Core 2 Quad/Core 2 Duo/Pentium/Celeron processors in the LGA775 package
- Support Intel® Yorkfield, Wolfdale
Supported FSB
Chipset
- North Bridge: Intel® P35 chipset
- South Bridge: Intel® ICH9 Base chipset
Memory Support
- DDR2 1066/800/667 SDRAM (8GB Max)
- 4 DDR2 DIMMs (240pin / 1.8V)
LAN
- Supports PCIE LAN 10/100/1000 Fast Ethernet by Realtek 8111B
Audio
- Chip integrated by Realtek® ALC888
- Compliant with Azalia 1.0 Spec
- Meet Microsoft Vista Premium spec
IDE
- 1 IDE port by JMicron JMB363
SATA
- 4 SATA II ports by ICH9.
- 2 SATAII ports by JMicron JMB363.
- Supports storage and data transfers at up to 300 MB/s
RAID
- Supports RAID 0, 1 and JBOD by JMicron JMB363. (SATA5,
SATA6)
FDD
- 1 floppy port
Connectors
Back panel
- 1 PS/2 mouse port
- 1 serial port (COM1)
- 1 parallel port supporting SPP/EPP/ECP mode
- 4 USB 2.0 Ports
On-Board Pinheaders / Connectors
- 4 USB 2.0 pinheaders
- 1 CD-In connector
- 1 Front Panel Audio pinheader
- 1 TPM pinheader(optional)
- 1 SPDIF-Out pinheader
- 1 Serial port connector
- 1 Chassis Intrusion Switch pinheader
Slots
- 1 PCI Express x1 slot
- 4 PCI slots
- Support 3.3V/ 5V PCI bus Interface
Form Factor
- ATX (30.5cm X 24.5cm)
MS-7353 - X38 Platinum Series
Processor Support
- Intel® Yorkfield, Wolfdale, Core 2 Extreme, Core 2 Quad, Core 2 Duo ,Pentium 4, Pentium D and Celeron processors in the LGA775 package
Supported FSB
Chipset
- North Bridge: Intel® X38 chipset
- South Bridge: Intel® ICH9R chipset
- Supports Intel® ViivTM technology
Memory Support
- 4 DDR3 DIMMs support DDR3 1333/ 1066/ 800 SDRAM (240pin / 1.5V / 8GB Max)
LAN
- Supports Giga LAN 10/ 100/ 1000 Fast Ethernet by Intel 82566DC (for ViiV)
Audio
IDE
SATA
- 4 SATA ports by ICH9R
- 2 eSATA ports by ICH9R
- 2 SATA ports by Silicon Image 5723 (SATA7 & SATA8 for storage devices with RAID funcion only)
- Supports storage and data transfers at up to 300 MB/s Intel RAID
- Supports Intel Martix Storage Technology (AHCI + RAID 0/1/5/10) by ICH9R
Silicon Image Hardware RAID
- Supports RAID 0/ RAID 1/ JBOD mode (for SATA7 & SATA8 only)
- Default mode is RAID 1
1394
- Supports 1394 by VIA VT6308P
FDD
- 1 floppy port
Connectors
Back panel
- 1 PS/2 mouse port
- 2 eSATA ports (support Command Based Port Multipliers)
- 8 USB 2.0 Ports
- 2 LAN jacks (10/100/1000)
- 1 1394 port (optional)
- 1 Optical SPDIF-Out
- 2 USB 2.0 pinheaders
- 1 1394 pinheader
- 1 chassis intrusion connector
- 1 SPDIF-out pinheader
- 1 CD-in connector
- 1 front audio pinheader
- 1 TPM Module connector (optional)
TPM (optional)
- Supports TPM
Slots
- 2 mazarine PCI Express x16 slots, support PCI Express 2.0 x16
speed
- 2 yellow PCI Express x16 slots, support PCI Express x4 speed
- 1 PCI slot, support 3.3V/ 5V PCI bus Interface
Form Factor
MS-7388 - K9A2 CF Series
Processor Support
- AMD® Phenom/Athlon/Sempron series processors in AM2/ AM2+ package
- Supports 4 pin CPU Fan Pin-Header with Fan Speed Control
Supported FSB
- AM2 CPU supports Hyper Transport 1.0
- AM2+ CPU supports Hyper Transport 3.0
Chipset
- North Bridge: AMD® 790X chipset
- South Bridge: AMD® SB600 chipset
Memory Support
- DDR2 800/667/533 DRAM (240pin/ 1.8V)
- 4 DDR2 DIMMs (8GB Max)
LAN
- Supports 10/100/1000 Fast Ethernet by Realtek 8111B
1394 (Optional)
- Controlled by VIA VT6308P (optional)
Audio
IDE
- 1 IDE port by SB600
SATA
- 4 SATAII ports by SB600
- 1 eSATA port by Silicon Image Sil3531(optional)
Floppy
- 1 floppy port
RAID
- SATA1~4 support RAID 0/ 1/ 0+1 mode
Connectors
Back panel
- 1 PS/2 mouse port
- 1 COM port
- 1 LAN jack
- 4 USB 2.0 ports
- 1 eSATA port (optional)
On-Board Pinheaders
- 3 USB 2.0 pinheaders
- 1 1394 pinheader (optional)
- 1 CD-in pinheader
- 1 TPM Module pinheader (optional)
- 1 SPDIF-out pinheader (optional)
- 1 Chassis Intrusion pinheader
TPM (optional)
- Supports TPM
Slots
- 2 PCI Express x16 slots compatible with PCIE 2.0 specification,
supports CrossFire mode
a. the mazarine PCIE x16 (PCI_EX1) slot supports PCIE x16 speed
b. the blue PCIE x16 (PCI_EX2) slot supports PCIE x8 speed
c. if you intend to install two expansion cards into both PCIE x16 slots, these two PCIE x16 lanes will auto arrange from x16/ x0 to x8/ x8
d. if you intend to install only One expansion card, make sure that the expansion card is installed on the mazarine PCIE x16 slot
(PCI_EX1)
- 1 PCI Express x 1 slot
- 2 PCI slots
Form Factor
- ATX (30.5cm X 22.0 cm)
MS-7366 - P6NGM series
Processor Support
- Supports Intel® Core 2 Quad, Core 2 Duo, Pentium, Celeron processors in the LGA775 package.
Supported FSB
- Supports FSB up to 1333 MHz (for 73U/PV)
- Supports FSB up to 1066 MHz (for 73V)
Chipset
- Nvidia MCP73U/PV/V chipest
Memory Support
- DDR2 533/667/800 SDRAM (240pin/ non-ECC) (for 73U/PV)
- DDR2 533/667 SDRAM (240pin/ non-ECC) (for 73V)
- 2 DDR2 DIMMs (4GB Max)
LAN
- Supports LAN 10/100/1000 Fast Ethermet by Realtek® RTL 8211BL (for 73U/PV)
- Supports LAN 10/100 Fast Ethermet by Realtek® RTL 8201CL (for 73V)
IEEE 1394 (optional)
- Chip integrated by JMicron JMB381
Audio
- Supports 7.1 channels audio out
IDE
- 1 IDE port by MCP73U/PV/V
- Supports Ultra DMA 66/100/133, PIO & Bus Master operation mode
SATA
- 4 SATAII ports support 4 SATA devices
RAID
- SATA1~4 support RAID 0, 1, 5 ,0+1, JBOD (for 73U/PV)
- SATA1~4 support RAID 0, 1, JBOD (for 73V)
Floppy
- 1 floppy port
Connectors
Back panel
- 1 PS/2 mouse port
- 1 VGA port
- 1 HDMI port (optional)
- 1 DVI port (optional)
- 1 IEEE1394 port (optional)
- 4 USB 2.0 Ports
- 1 LAN jack
- 6 audio jacks
On-Board Pinheaders
- 3 USB 2.0 pinheaders (for 73U/PV)
- 2 USB 2.0 pinheaders (for 73V)
- 1 IEEE1394 pinheader (optional)
- 1 Serial port pinheader
- 1 CD-In pinheader
- 1 TPM pinheader (optional)
Slots
- 2 PCI slots, support 3.3V/ 5V PCI bus Interface
Form Factor
- M-ATX (24.4cm X 22.0cm)
MS-7373 - K9AGM4
Prozessoren
> AMD® Athlon64 / Athlon64 X2/ Sempron Prozessoren für Socket AM2
> Unterstützt CPU Lüftersteuerung über eine 4-polige StiftleisteS
FSB (Front-Side-Bus)
> 1000 MHz
Chipsatz
> North-Bridge: AMD® RS690V Chipsatz
> South-Bridge: AMD® SB600 Chipsatz
Speicher
> DDR2 800/667/533 DRAM (max. 4GB)
> 2 DDR2 DIMMs (240 Pin / 1.8V)
LAN
> Unterstützt 10/100 Fast Ethernet über 8101E
> Oder unterstutzt 10/ 100/ 1000 Ethernet über 8111B (optional)
Audio
> Onboard Soundchip Realtek® ALC888
> 5.1- Kanal Audio-Ausgang
> Erfüllt die Azalia 1.0 Spezifikation
IDE
> 1 IDE Port über SB600
> Unterstützt die Betriebmodi Ultra DMA 66/100/133 mode
> Unterstützt die Betriebmodi PIO, Bus Mastering
SATA
> 2 SATAII Ports über SB600, unterstützt 2 SATA Gerät
> Unterstützt Datenübertragungsraten von bis zu 300 MB/s
Disketten Laufwerk
> 1 Disketten Anschluss
> Unterstützt ein Diskettenlaufwerk mit 360KB, 720KB, 1.2MB, 1.44MB oder 2.88MB
Kapazität
Anschlüsse
> Hintere Ein-/ und Ausgänge
- 1 PS/2 Mausanschluss
- 1 PS/2 Tastaturanschlus
- 1 Serielle Schnittstelle
- 1 VGA Port
- 1 Parallele Schnittstelle, unterstützt die Betriebsmodi SPP/EPP/ECP
- 4 USB 2.0 Anschlüsse
- 1 LAN Buchse (10/100)
- 3 Audiobuchsen
> On-Board Stiftleiste / Anschlüsse
- 1 USB 2.0 Stiftleisten
- 1 Audio Stiftleiste für Gehäuse Audio Ein-/ Ausgänge
- 1 CD Stiftleiste für Audio Eingang
Schnittstellen
> 1 PCI Express x16 Schnittstelle
> 2 PCI Schnittstellen
Form Faktor
> Micro-ATX (24.4cm X 20.4 cm)
MS-7382 - K9AGMD series
Prozessoren
> AMD® Athlon64 / Athlon64 X2 / Sempron AM2 Prozessoren für Sockel SKT940
> Unterstützt bis zu 5000+ CPU (Wir empfehlen Gebrauchprozessor mit 65w und unter 65w Leistungsaufnahme)
> 1000 MHz
Chipsatz
> North Bridge: AMD® 690V Chipsatz
> South Bridge: AMD® SB600 Chipsatz
Speicher
> 2 DDR2 DIMMs (240pin / 1.8V)
LAN
> Unterstützt PCI Express LAN 10/100 Fast Ethermet über Realtek® 8101E Audio
> Onboard Realtek® ALC888 Soundchip
> 8- Kanal Audio-Ausgang
> Erfüllt die Azalia Spezifikationen
IDE
> 1 IDE Port über SB600 South Bridge
> Unterstützt die Betriebmodi PIO, Multi-word DMA
SATA
> SATA II Ports über SB600 South Bridge
> Unterstützt 2 SATA II Geräte
RAID
> Unterstützt RAID 0, RAID 1 über SB600
Anschlüsse
- 1 PS/2 Tastaturanschluss
- 1 VGA Anschluss
- 6 Audiobuchsen
- 2 USB 2.0 Stiftleisten
- 1 Gehäusekontaktschalter
- 1 Serielle Stiftleiste
Form Faktor
> Mini-DTX (20.0cm X 17.0 cm)
neue MSI-Boards
« Antwort #1 am: 08. Oktober 2007, 23:29:48 »
Holla die Waldfee, das ist ja gleich ein halbes Dutzend auf Schlag! 8o
Leider sind alle AMD-Bretter noch mit dem alten SB600 bestückt... :(
« Letzte Änderung: 01. Januar 1970, 01:00:00 von 1191878999 »
neue MSI-Boards
« Antwort #2 am: 09. Oktober 2007, 16:54:05 »
IDE  - 1 IDE port by JMicron JMB363  - Supports Ultra DMA 66/100/133 mode  - Supports PIO, Bus Master operation mode
Ich dachte wir wären den unglücklichen Jmicron Controller auf zukünfigen Boards los. Dem soll wohl so nicht sein.
Das P35 Neo3 ist anscheinend ein geliftetes P35 Neo-F.
neue MSI-Boards
« Antwort #3 am: 09. Oktober 2007, 17:11:24 »
P965 Neo, P965 Plat. und 975X Plat. PUE hatten einen JMB361 Controller verbaut, es handelt sich also immerhin um eine andere Version.
Der Marvell-Controller hat offensichtlich auch seine Ecken und Kannten. In sofern war JMicron vielleicht keine so schlechte Idee.
Den JMicron-Controller (JMB 361) habe ich übrigens sehr zu schätzen gelernt.  Meine Systemplatte (SATA) hängt an diesem Teil und ist da sogar etwas schneller als am ICH7DH Controller.
« Letzte Änderung: 01. Januar 1970, 01:00:00 von 1191942713 »
